Rear end swap on a 98 3500 DRW
Hello all, my 98 single cab DRW 3500 12v 5 speed broke down AGAIN for the 2nd time this month since I have owned it, first the clutch now the rear with only 112,000 miles on it,.
I found a local rear end out of a 94 dodge ram 2wd 3500 DRW 12v that is a 4:10 Posi not the lower 350 gear I have now.....will this work ? I plan on using the rear leaf springs as well....
Received 1,637 Likes
Should work just fine, I too break something every time I drive my CTD (honestly) as I drive it hard and rage rough roads like I do my Toyota, but something always breaks. Today I pulled out my cup holder and it came right out of the dash. Day before that I stomped the Ebrake to help in a tight turn and herd a loud pop, no more ebrake just floats to the floor.
Is your truck a cab and chassis or a pickup? Same question for the donor. If they are different, the axle widths will be very different. If yours is a 4wd, the perches on the axle will have to rotated (or shimmed). Oil pans are also different between the 2wd and 4wd. Lastly, I wouldn't trade 3.55's for 4.10's unless all you do is towing.
I usually only work on 4x4...but that is news to me.
DODGER BOMBER
02-26-2015 06:22 PM
vachand
04-29-2011 08:39 AM
jlipskoc
03-07-2009 08:00 PM
dragginlx
15
03-09-2007 11:32 AM
LT500Rider
11-30-2006 10:46 AM
