Rear Brakes!
Originally posted by apache
Will those cylinders work on a 93 350 dually?
I suggest you go the Napa and ask for the cylinder for your rig and the 4637337 at the same time and size them up to each other.
Let us know.
chev rear cylinders
I bought a set and installed them. They do help. I guess that is all that I can get out of the rear. My son told me that someone is selling a kit to install disc brakes off a chev that was not to high.It would not have a parking brake. If that is true I could live with it if I got better brakes. Jimk
After reading this post I decided to give the GM brake cylinders a try. It made a huge difference in stopping power. Am anxious to see how it is towing the fiver.
Great suggestion.
Great suggestion.
Originally posted by dieselman24
I just did mine last night and can not tell a diff at all and I used the wagner brand...
You may not have gotten it bled all the way or if you used the pump the pedal method of bleeding could have damaged a master cylinder seal.
I have a one man bleeder sytem and it works great never had any problems with it did another truck with the cheap ones Saturday night and no difference either both trucks had all the brakes and springs replaced drums turned less than a month ago...So im not sure what the deal is...
There has to be a common denominator somewhere, most folks feel the difference the first time they step on the brakes.
1992 Renegade
10-11-2014 03:29 PM
2500CTD
10-19-2010 07:10 PM
JImbo1
13
04-18-2003 06:44 AM
