Radiator Drain
Old Sep 29, 2006 | 11:03 AM
schoust's Avatar
Radiator Drain
Hey guy's here is another silly question,Im changing my hoses over the weekend and I was wondering where the elusive petcock is for the radiator?I looked quikly the other day but did not see it??? Thanks in advance!!
Old Sep 29, 2006 | 11:14 AM
Mcmopar's Avatar
Drivers side of the radiator down low on the engine side of the rad. 1/4 turn and then genly pull out. It has a fitting to put a small hose onto.
Old Sep 29, 2006 | 12:11 PM
DL1221's Avatar
I don't bother with the petcock, I just disconnect the lower radiator hose to drain the coolant, then pull out the radiator to make sure it's flushed well.
By the way, what new upper and lower radiator hoses are you using? I tried the dealer, but they were very expensive and had to ordered.
Old Sep 29, 2006 | 12:14 PM
Mcmopar's Avatar
I prefer the petcock, a bath in the green stuff sucks!!
Old Sep 29, 2006 | 12:22 PM
SoTexRattler's Avatar
My rad. petcock was stopped up inside .. Being plastic, I decided not to screw with it and risk not getting it sealed off again. I just stuck a hose down the rad and siphoned the majority out into some empties. That really reduced the amount of "GUSH" when the bottom hose comes off.
K.
Old Sep 30, 2006 | 07:26 AM
schoust's Avatar
Thanks guy's I got mine from the Dealer,and yes they were expensive,the only reason I did this was turn around time,my local Napa could have gotten them but I would have had to wait......
8liter
Sep 22, 2012 10:19 AM
klx650a2
Jan 10, 2008 12:08 AM
6cylinders
Mar 6, 2004 03:57 PM
015speed
Jun 16, 2003 04:58 PM
015speed
May 24, 2003 10:24 PM
