Pull Start?
Old Apr 6, 2011 | 05:23 PM
Silver Ram's Avatar
Pull Start?
I pulled into Culvers 60 miles from home to get a cheeseburger and as usual got the customary "could you shut your truck off I can't hear you" Shut it down and ordered 2 cheesburgers. Went to start and click. Click CLick. 5 cars behind me. I managed to push it out of the way so they could get by. I saw a tow sign in the parking lot so I called. $55 bucks to come pull start me. I got under the truck with a screwdriver and tried to bump te starter until it wouldn't spark anymore. No luck. An hour later the tow truck shows up, hooks up and I throw it in second. He gets me going about 15 mph down the parking lot and i pop the clutch. Nothin. We do this repeateadly until we decide one more try then tow me. It catches.
Is there some interlock on the fuel soleinoid and the ignition key? I can't believe my truck was that hard to pull start. I had the key on but does the starter need to engage to make the solenoid function?
Thats the most expensive cheesburgers I have ever bought!
Old Apr 6, 2011 | 06:03 PM
Tate's Avatar
The solenoid won't lift until the starter has power. If you don't put the key to the start position, the solenoid won't lift.
Next time, pop the solenoid up first then do the pull. I've had to do that a couple times when my starter died.
Old Apr 6, 2011 | 08:37 PM
cj360trider's Avatar
What Tate said^^^
Old Apr 10, 2011 | 04:04 PM
Silver Ram's Avatar
put new starter in and it just clicks, now what?
Old Apr 10, 2011 | 08:07 PM
rattlerbob5.9's Avatar
Relay,connections or a bad cable/wire.
Old Apr 10, 2011 | 10:51 PM
schamran's Avatar
I had the same thing happen last week. It ended up being a bad end on the ground cable.
Don't leave the positive cables hooked up to the battery while removing the ground cable! I think that's how I fried my computer....
Old Apr 18, 2011 | 05:19 PM
Silver Ram's Avatar
It turns out there was a wire that comes off the possitive terminal that only had one good strand left. It wasn't the fuseable link but the other one. I put a new connector on it and it fired right up. New starter is a big improvement too. Only bad thing is its one of those $100 chinese knock offs. Someone had already replaced the Denso with one so I had to do the same. No Denso to rebuild.
Old Apr 19, 2011 | 09:46 AM
infidel's Avatar
Who knows, your new rebuilt could have been a quality core to begin with.
It's pretty much luck of the draw.
CoolumConst
Oct 11, 2008 10:00 PM
dodgemaniac
Competition / Pulls / OffRoad
Aug 5, 2007 12:42 PM
PourinDiesel
Jul 21, 2007 12:42 PM
Bobcat698
18
Aug 3, 2006 09:23 PM
zookeeper
Jul 19, 2005 09:40 PM
