| texasprd |
Apr 13, 2020 04:55 PM |
If by "through the factory" you mean a dealership, I very much doubt that front-end parts for a 23 year old truck are still available through the dealer. In any case, they weren't actually made by Dodge/Chrysler Corp to begin with. Moog used to be as good a name as there ever was for front-end parts - a lot of people say Moog isn't what it used to be, though. Dana/Spicer is supposed to have been just as good, but from what I can tell by following merger/divestiture announcements that come up in Google searches, Dana sold off it's chassis-parts line and it eventually wound up under Federal-Mogul, which owns Moog. I cannot find Dana/Spicer ball joints for a 2WD, but I do see them advertised online for some 4WD front-axle models. I don't know if you have a 2WD or 4WD - I don't see a signature line. Since I have a 2WD, those are not of interest - if you have 4WD, you will have to investigate that on your own or see if someone else here has insight on them. I have also heard of other supposedly very high quality (expensive) ball joints for 4WDs if that's your platform. I have heard some good words about Proforged (possibly mfg'd in Taiwan, designed here?) - no personal experience with those, though. Mevotech shows up in RockAuto's "heavy duty" recommendations - I have no first-hand knowledge of them, either. If you don't already know, be aware that often a manufacturer or brand has multiple quality levels, so be sure to get the top line if you can.
Pardon the elementary question - but when you replaced everything, did you bleed the power-steering and hyrdoboost systems properly? How sure are you about the work done by others after you?
