Play in turbo
Old Nov 17, 2009 | 05:19 PM
Onemoparnut's Avatar
Play in turbo
How much play is bad in the shaft of a turbo? The turbo is off a 97 dodge 3500 I am not sure what turbo it even is. I can move the shaft up and down and side to side a little bit. Can these be rebuilt?
Old Nov 17, 2009 | 06:02 PM
cmac's Avatar
yes they can be rebuilt. if i am not mistaken i think a little front to back shaft play is ok but side to side isnt. i may have that backwards.... someone please confirm
Old Nov 17, 2009 | 06:39 PM
Also could someone please tell me what turbo would be the stock one for this truck?
Old Nov 17, 2009 | 06:48 PM
Tate's Avatar
Radial play is fine so long as it doesn't touch the compressor housing. Axial play is what you want to avoid. '97 will have an HX35W on it.
Old Nov 21, 2009 | 12:39 AM
Astro's Avatar
Side to side play is ok...as long as it doesn't rub the housing or seem excessive. Thrust play (in & out) is no good and must be fixed or it won't last very long.
HX35W's are easy to rebuild. A Holset rebuild kit off the internet or turbo shop, a bench vise, some hand tools, and a pick and you can rebuild it yourself in less than an hour. The compressor wheel must be properly torqued and clocked on the turbine shaft to the same position it was in when removed otherwise it will be off balance. Most turbo shops charge about $250-$350 for a basic rebuild.
captntim
Dec 26, 2008 02:53 PM
SHARPMACHINE
Jul 27, 2004 12:57 PM
yrusoslow2
Feb 16, 2004 10:02 PM
apache
Dec 27, 2003 09:32 PM
figure_9_pro
Apr 6, 2003 11:42 PM
