axle swap
Old 10-28-2017, 10:56 AM
olddodgetrucks's Avatar
axle swap
I can get a complet rear axle from a 2004 and want to put it in my 1995,what do I need for the swap?/ thanks
Old 10-28-2017, 11:40 AM
Received 2,385 Likes on 1,575 Posts
Is it 4x4?
If so, I would check the axle ratio and make sure it is a match first.
Old 10-28-2017, 12:57 PM
2wd just want disk brakes,have 17 in tires/rims
Old 10-28-2017, 01:03 PM
I have never used a 3rd gen axle on a 2nd gen, but I could see, leaf spring perch distances apart, leaf spring widths, rear driveshaft U joint and maybe even driveshaft length being different / a problem.
I would recommend checking them both out with a tape measure, checking u-joint #s, and such would be the way to proceed.
You have the 17 inch rims already. so that will not be an issue.
rustydeeretech
17
05-21-2011 03:05 PM
ridofpwrstroke
08-25-2006 05:24 PM
MX429
08-20-2006 06:41 PM
04ctd
04-05-2005 11:59 AM
Paul Winey
06-22-2004 08:09 AM
Quick Reply: axle swap
