passenger side front tire wear
Old Feb 13, 2008 | 11:37 AM
greenrig's Avatar
my truck pulls to the right and the passenger side front tire is worn on the outside. i'm sure one or most of the front end bushings are gone but i was hoping that this would be a tell-tale sign of a particular one (and an easy one that i could tackle)
all other tires are wearing even. thanks
Old Feb 13, 2008 | 12:28 PM
wcbcruzer's Avatar
Just make sure it's not the wheel bearing or one day you may see your wheel coasting along side with you on the freeway. Jack up that side, grab the top and bottom of the wheel and wiggle to see if there's any play.
Old Feb 13, 2008 | 05:42 PM
dozer12216's Avatar
Assuming nothing worn like a ball stud, an alignment check should find. If camber is off excessivelly , offset joints are avalaible. I recomend very low toe setting for highway operation.
Old Feb 13, 2008 | 05:52 PM
Baja's Avatar
Mine is doing the exact same thing. Maybe it is a result of hitting a rock so hard that I cracked the frame where the steering box is bolted to it. I had the alinement checked, rotated the tires and will be watching the wear pattern. I am starting to save $
Dave88LX
14
Sep 1, 2011 11:36 AM
AlpineRAM
0
Sep 25, 2007 03:17 PM
wexman
20
Nov 25, 2006 10:17 AM
carpenterje
Feb 16, 2006 09:21 PM
ramman21921
Oct 12, 2003 09:36 PM
