Overdrive switch
Overdrive switch
I bought a 98 12valve 2 wheel drive auto last fall. Not a bad truck, runs well except the overdrive off/on switch is not working.The overdrive does not cancell when its pushed. Its on the end of the gear shift and Im not sure what to look for. Any suggestions please?
The wires go down through the shifter into the column and I've seen the wires break a couple of times where they flex every time the shifter gets moved. Remove the upper shrouding from the column and have a look at the wire from the shifter down toward the connector. Chances are good you'll see a break.
72demon440
Apr 27, 2007 10:45 PM
electrifried
Oct 10, 2005 07:11 AM
RTharaldson
Jan 24, 2005 09:27 AM
