oil light flickers.....
Old 07-07-2019, 07:09 AM
pipefitter's Avatar
1996 2500 automatic 4x4 with 174,000 miles. All stock. In the past few months, I have noticed the low oil light flicker occasionally when stopped, but the gauge reads fine. The oil level is good. Could it be a sending unit? I've had them go bad on other vehicles.
Old 07-07-2019, 07:56 AM
AlpineRAM's Avatar
I'd check for a chafed wire to the sending unit first.
Old 07-07-2019, 08:38 AM
Received 2,392 Likes on 1,576 Posts
X2
I might throw a mechanical gauge on for just a quick check to make sure it has good oil pressure.
My factory oil "guess-o" gauge on the dash was reading lower than I like to see on my '91.0. I threw a hard line and aftermarket oil PSI gauge that I attached to the top of the oil filter housing to double check it. Apparently 65 PSI is less than 1/4 on the factory gauge and 35-40 PSI when the engine is hot at idle barely reads on the factory gauge.
BKR
02-14-2013 06:22 PM
bbrinkman2003
07-09-2010 11:39 AM
aggiebowhunter
10-05-2009 10:12 PM
farmer0_1
01-29-2007 12:03 PM
auSS/Tin
01-18-2007 09:09 PM
Quick Reply: oil light flickers.....
