-   12 Valve Engine and Drivetrain (https://www.dieseltruckresource.com/forums/12-valve-engine-drivetrain-100/)
-   -   Nv5600 in 12v (https://www.dieseltruckresource.com/forums/12-valve-engine-drivetrain-100/nv5600-12v-333947/)
wastarr03 Dec 4, 2020 07:03 AM
Nv5600 in 12v
Doing nv5600 swap in my 97 12v and saw a guy who jacked up the front of the motor so he could get it in there easier. Is this necissary or am I able to squeeze it in without jacking tilting the motor?
oliver foster Dec 4, 2020 09:01 AM
I tilted up the front of the motor a tiny bit when I installed my last NV-4500 to make it easier.
I would do the same on the NV5600.
Is it a needed step, maybe not, but it makes it easier on me, so I do it as it is quick and easy.
wastarr03 Dec 4, 2020 09:04 AM
Do I need to undo motor mounts or anything or can i just use a block of wood and floor jack on the front?
oliver foster Dec 4, 2020 11:33 AM
I loosened my motor mounts and removed my down pipe when I did my clutch and NV-4500 job last time.
I was upgrading the down pipe anyway, but it sure helps with getting the engine to tilt easily, if it is not mounted.
