NV4500 oil
Old Mar 2, 2006 | 12:24 AM
sammy340's Avatar
NV4500 oil
Anyone know what the best oil is to use in the NV4500 and how much it takes?
Thanks
Jeff
Old Mar 2, 2006 | 07:41 AM
displacedtexan's Avatar
From dodgeram.org
# Fluid Capacity: 8.5 pints
* Fill level is to the bottom edge of the fill plug hole.
* These are the ONLY lubricants recommended for the NV4500:
o 75W-90 Castrol Syntorque Synthetic
o Mopar Manual Transmission Lubricant (PN 4637579)
o GM Transmission oil (PN 12346191)
o NOTE: Syntorque is NOT the same as Castrol Syntech.
Amsoil makes a lube for it as well...
Old Mar 2, 2006 | 08:03 AM
Dr. Evil's Avatar
Using anything other than the OEM lube can wear the fibre syncros prematurely....and cause failure. You can get away with different fluids in the 6 speed but not the 5 speed.
Check some GM dealers - sometimes they sell the Castrol Syntorque for much cheaper.
SilverSootXpres
Mar 23, 2010 07:18 PM
J Lent
30
Jun 15, 2007 12:42 PM
Common
Sep 15, 2006 08:02 PM
CTDinMT
Jul 26, 2006 09:36 PM
Lil Dog
18
Nov 1, 2004 05:34 PM
