No TCC signal
Old Dec 27, 2007 | 09:49 PM
andy2's Avatar
No TCC signal
Hello,I'm working on a 94 that has no TCC signal from the PCM going to the TCC solinoid (orange wire w/black stripe).The scan tool indicates that the TCC signal is "off" and not being switched.There are no codes and Overdrive works,TPS reads good,temp sensor reads good.I'm just wondering if anyone has ran into this issue before as I did search the forum and came up with no similar cases.Also the odd time the signal is there and then its gone.The truck has a BD Exhaust Brake,Pressure loc and Auto loc on it so without the TCC working this stuff is dead weight.I'm thinking the PCM is the problem but have never seen one fail before.Anyone else replace a pcm to resolve this issue?
Thanks
Old Mar 18, 2008 | 01:39 PM
andy2's Avatar
Does anyone know if the brake switch has anything to do with the TCC?
Old Mar 18, 2008 | 02:00 PM
Lil Dog's Avatar
Yes the brake light switch will cancel TCC lockup. I would look at that first.
Old Mar 18, 2008 | 06:49 PM
andy2's Avatar
Thanks for the reply,I will look into that and report back when i see the truck again.
Old Mar 19, 2008 | 08:59 PM
kevellis32's Avatar
what exactly do you mean by brake switch
Old Mar 19, 2008 | 10:14 PM
Lil Dog's Avatar
The switch under the dash that touches the brake pedal. It has a tendency to pop out of position or wear and cause all kinds of lockup problems with the TCC.
sgT
Aug 1, 2004 11:28 PM
vtailflyer
Apr 2, 2004 10:54 PM
daystar
Feb 19, 2004 06:21 PM
slayerfish
Jan 7, 2003 08:08 PM
RickCJ
Dec 18, 2002 02:23 PM
