need to remove auto trans 95 ctd
Old Feb 5, 2012 | 12:06 PM
FredM's Avatar
New to these things, but need to remove trans and replace flex plate.
any tips?
Not into these newer pickups, but this one is a 95 3500 4 door, yes four door.
Want to get if fixed and send it down the road.
So is there anything special that I should know to remove the trans?
thanks
Old Feb 5, 2012 | 05:47 PM
j-fox's Avatar
No. Just unbolt it.
Old Feb 5, 2012 | 10:24 PM
cj360trider's Avatar
if you ave a port a power you may want to use it to spread the frame rails to make it easier getn the cross-member out. and take a good look at ur cooler lines while ur in there. if you can swing a low stall converter youll be doing urself a favor as well
Old Feb 6, 2012 | 04:54 PM
FredM's Avatar
Question
washing some of the dirt and grease that has accumulated over the years,
Have read thet the crank position sensor needs removed first, Why is this?
Old Feb 6, 2012 | 08:52 PM
rattlerbob5.9's Avatar
That would NOT be correct for the 94-98 model years diesel, their would be no need to remove it to pull the tranny unless you have a 5.9 gas engine.
MikeRP
79
Nov 21, 2016 10:19 PM
RoadDiesel
Aug 7, 2012 06:06 PM
97CTD
Jul 29, 2007 08:22 AM
AgentOrange
Jul 14, 2006 05:50 AM
Dodgezilla
Jul 17, 2004 05:24 AM
