Need Help Please
Old May 13, 2007 | 09:58 AM
standingbear's Avatar
Need Help Please
I have a 98 12v with 185,000 miles manual tranny, 4 in straight pipe, my waste gate went out about 140,000 replaced with banks also came with fuel plate. that is all i ever did to my truck. Im not the brightest on diesel engines so all help would be good. I have lost a lot of power i even have to start out in first gear now. when i first start it a lot of white smoke comes out. it is worse when its cold out. then when it warms up an a lot of black smoke comes out. sometimes when i accelerate it stumbles real bad then sometimes it doesnt.
last time i drove it down the interstate at steady speed it stalled. i pulled over an it started right back up. did it about 3 more times in about 200 miles.
Old May 13, 2007 | 10:12 AM
Box5's Avatar
Have u checked ur fuel lines all the way back to the tank for cracks or leaks? That will cause air to get in the system and create some white smoke and stumble, but mostly on startup and when the engine is still cold. Also ur timing has probably slipped back.
Old May 13, 2007 | 10:31 AM
Thanks i will check my fuel lines. how do i set my timing. also this may sound stupid but can some one explain the fuel system from gas tank to injector i keep reading about all these different pumps all over the truck. is there a filter in the gas tank .
Floridacracker
Jun 17, 2008 11:20 AM
SuperiorRam
Mar 15, 2007 03:10 AM
ocsurf16
Sep 16, 2006 09:23 PM
dslpwr81
44
Jan 13, 2006 11:32 PM
smoke20
13
Jan 1, 2005 04:13 PM
