melted fuel preheater air leak
Old 06-10-2009, 12:03 PM
cheapskate's Avatar
finally got around to finding my air leak, and it seems to be the plastic "elbow" the connects to the fuel preheater on top of the strainer bowl. with the wiring connected it smokes! and leaks! so, should i replace everything-heater,harness,strainer,etc? i think i would rather eleminate all of the fuel heater stuff, but that still leaves me with a leak where the connector has melted. is the anyway to plug that hole, or fix that leak? i unplugged the harness for now to prevent any further melting or fire.
cheapskate is offline
Old 06-10-2009, 12:12 PM
cheapskate's Avatar
heres a blurry picture of the problem. the electrical connection on top with the two wires has melted a little, causing the air leak.
Old 06-10-2009, 07:03 PM
Unless you live in an arctic climate you don't need the heater.
It's very easy to eliminate.
You'll find instructions here http://www.cumminsforum.com/forum/94...m-writeup.html
If you want to fix it here's part numbers from Cummins
heater strainer kit 3845400-S
heater element 3907766-S
cable harness 3843722-S
or you can get the parts here
Harness
Service Kit
Heater Element
infidel is offline
Old 06-10-2009, 08:06 PM
cheapskate's Avatar
thanx. i had already gotten the info from genos, but i appreciate the heater delete thread. my question is that since my leak is from the temperature sensor, how will removing the heater do anything to fix that. i would think that since the temp. sensor is on top of the housing, my leak would still be there, right?
Old 06-10-2009, 08:20 PM
Diagram doesn't show it well but when you get it apart you'll see that once the heater assembly is removed and the bottom bowl reattached it cuts off fuel to the sensor section of the top.
infidel is offline
Old 06-11-2009, 05:40 AM
cheapskate's Avatar
ah, excellent. thank you so very much. looks like i will be taking it out of there.
Old 06-11-2009, 06:54 AM
blackimpala's Avatar
Removed mine
I took mine out Over three years ago and haven't missed it since. I live in Wash. state and it can get pretty cold here.
Floyd
blackimpala is offline
91.5CTDBanks
01-13-2010 08:13 PM
snakefarmer
10-31-2005 07:38 PM
bek
21
09-14-2005 05:59 PM
12vordie
06-25-2005 01:14 PM
rigsy
10-26-2002 04:17 AM
Quick Reply: melted fuel preheater air leak
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
