Manual transmission oil
Old Jan 24, 2006 | 12:10 AM
alaskanassassin's Avatar
Can I use Mobil 1 type SHC 626 in my NV4500? This is a synthetic oil for bearings and gear oil. 80 to 90 weight. Thanks Doug
Old Jan 24, 2006 | 12:19 AM
Barry Smith's Avatar
I don't think so. They recommend the Castrol Syntech. You can order it for $54/gal. or buy it at the dealership for $60 $15/qrt. I hate to pay that but it is a pain to take the transmission out I've done it twice already!
Good luck
Barry
Old Jan 24, 2006 | 12:20 AM
I forgot to mention it is a 5 speed manual. Thanks Doug
Old Jan 24, 2006 | 01:11 AM
pind's Avatar
Amsoil MTG 75/90, made as a direct replacement for castrol syntorque, and much cheaper. I have been using the amsoil for about 30,000 km now, and have had no trouble with it. It is formulated for the nv4500 series trans.
Good luck
Old Jan 24, 2006 | 06:53 AM
jrs_dodge_diesel's Avatar
Good luck
Barry
I think you mean Castrol Syntorque. Available at both Dodge and GM Dealers (yes GM used the NV4500 in some of thier vehicles). Similar pricing either way.
BTW the Syntorque is one of the very few approved oils for use in the 4500. This is beacuse of the heat range of the oil is higher than most oils due to the 4500 having special synchros.
Old Jan 24, 2006 | 08:22 AM
What is the black box on the passenger side of manual transmission, looks like a filter set up. It is on the opposite side of the inspection plate. I could not find any thing in the shop manual on this. Later
Old Jan 24, 2006 | 09:54 AM
Lil Dog's Avatar
That sounds like an aftermarket filter system. I have seen them floating around at different shops.. The real plus is the extra capacity added.
Here is some good info on the 4500. Bookmark this site, you will be reading for hours.
NV4500 Info
Old Jan 24, 2006 | 10:02 AM
infidel's Avatar
There are aftermarket filter setups that install where a pto would go, sounds like you have one.
I would never even consider using anything but Castrol Syntorque in my 5 speed.
Others may say that Redline, Amsoil, etc works but doubt if many have run it 100k miles plus to really know. The material the NV syncros are made from are very specific to the lube used and slowly dissolve with the wrong fluid.
Standard Transmission http://www.standardtransmission.com/ has Syntorque for $54/ga
Don't let anyone try to sell you SynTech, it won't work.
Old Jan 25, 2006 | 01:54 AM
You right I was getting all the syn stuff mixed up. Sorry if I confused you Alaskan!
Old Jan 25, 2006 | 01:58 AM
Thanks for all your input. Got the oil changed and put a blank cover over where the filter was. Ended up using Mopar gear oil, GL-4, which was $15 dollars a quart. Does any know how much the Ams oil series 2000, synthetic, 75/90 weight, gear oil is a quart. I see it is rated GL-2 thru GL-5. Thanks agin.
Old Jan 29, 2006 | 09:25 AM
Thanks for all your help. I just got a free sample magazine from TDR today, issue 33, and they really praise the Castrol Syntorq. Also got in a Geno's catalog and the filter I was talking about is in there. Holds an extra 8 oz. Later
jj3500
Aug 31, 2012 10:31 AM
ups132
Mar 2, 2010 04:42 PM
banana
17
Oct 14, 2008 10:52 PM
TXOVAL
Jan 28, 2007 09:54 PM
ezdemon72
14
Jul 29, 2005 10:05 AM
