Manifold Gasket
Old Oct 11, 2006 | 12:16 PM
txdodge97's Avatar
Manifold Gasket
What is the easy way to replace the manifold gaskets? My number 1 is blown and leaks soot all in the engin capartment.
Old Oct 11, 2006 | 07:03 PM
Paul Winey's Avatar
txdodge97:
The gaskets are a compression/crush type metal gasket. You won't be able to easily replace just one as you will have to loosen all bolts and risk leaks with the others. You could try and slip one in but if you've been having blow-by then it is probably carboned up and you will need to clean up the head and manifold surface. It's not a bad job, just soak everything with powerblaster a few times. You can probably get by with leaving the turbo and manifold bolted together if you have room to work. While you're at it you might as well replace it with a 3-piece from HTT or ATS. Remember to follow the tightening sequence and torque.
Paul
jmccart
14
Jul 31, 2008 11:46 PM
silkywoods
35
Feb 6, 2008 12:40 PM
Dusty Ratcliff
Apr 2, 2006 11:08 PM
RedRider
Mar 10, 2006 09:27 PM
