low sulfer fuel in a 12 valve
I've heard of a few pump problems using the low sulfer fuel. Not enough lubrication. Any comments?
1995 2500 slt 4x4 365,000 fuel plate, kn filter, 16cm turbo, 4" exhaust, air bags and compressor, air horn tst tranny with lockup
Just make sure your using one of the many over-the-counter proven additives and you will be fine.The harshness of the low sulfur fuel will eat away at orings and seals inside the pump.I use the Stanadyne Performance Formula and when I had a new P-Pump built recently and my pump man went through my old one nothing out of the ordinary was seen........Andy
I've read in the TDR mag's there is no issue with running the new fuel in our pumps.
But I aggree running additives just in case.
ULSD has low lubricity... as stated before our P-pumps are oil lubed, so it's not as big of a deal with us as it is with many. One thing that I always keep in mind is the fact that one of the reasons, among others, that diesels have such great longevity is the fact that the fuel helps lubricate the rings, rather than combating the oil on the cylinder walls like gasoline does. I anticipate seeing a lot of diesel losing their rings much earlier than they have in the past with the previous diesel that we were buying. I always add a quart or two of 2 cycle oil to a tank of fuel just for a little peace of mind.
refiners have stated numerous times that they are aware of that and add lube back to replace it.
Me thinks the ULSD fears are exactly the same as when lead was removed from gasoline- unfounded.
