Low power Low boost
Old Aug 14, 2015 | 02:10 PM
dirty dozen's Avatar
Low power Low boost
Hey gentleman I've been trying to troubleshoot a low power condition on my 97 ram. I know I have a low fuel pressure condition 13 psi at idle and 20 psi at 2000rpm. I'm also only making 10 pounds boost at WOT. Today I noticed the vacuum pot on my wastegate actuator is cracked. Would this be contributing to a low boost low power condition? Thanks in advance for your help.
Old Aug 14, 2015 | 06:00 PM
patdaly's Avatar
It might contribute, but you have to have fuel to build boost, and low supply pressure to the IP will limit your fuel to build boost............
Any idea on why your supply pressure is so low?
Old Aug 14, 2015 | 06:16 PM
I'm pulling my hair out trying to figure out why the fuel ptessure is so low patdaly. I've changes or cleaned all my filters and screens including the in tank screen. I've changed my overflow valve to a tork tek adjustable one. I've checked all my fuel lines as well. I'm thinking my lift pump may be getting worn out. Not really sure what to do next other than replace the lift pump. Any suggestions? Thanks.
Old Aug 15, 2015 | 04:03 PM
bjytech's Avatar
To check to see if the lift pump is weak find the rubber part of the return line (between engine and frame) and pinch it off with pliers while you have someone watch the fuel pressure. if pressure jumps up its a overflow valve problem if it doesn't jump up its a lift pump/fuel supply problem.
Old Aug 15, 2015 | 06:34 PM
Thanks I'll try that but I've just replaced the overflow valve and it only has about 100 miles on it.
Old Aug 16, 2015 | 11:58 AM
Okay guys I'm beyond confused now. I pinched my return line and my pressure spiked to over 20 psi. I just replaced the overflow valve so what does this mean? Did I get a bad valve? Do I need to replace it again???? Does this spike in pressure point to anything other than an overflow valve issue? Help!!!!!!😣😣
Old Aug 16, 2015 | 03:24 PM
Turbo67's Avatar
10 Year Member
Any chance you switched the return banjo bolt with one of the supply banjo bolts? I think the return one has a very small orifice.
Any chance you have installed a pressure adapter into the bleed port on the banjo bolt that is longer than the stock bleed screw and is restricting fuel flow to the injection pump?
Old Aug 16, 2015 | 03:35 PM
The shiny new one is the overflow valve that I replaced it's on the front of the ip. According to the manual it's in the right spot. My pressure guage is threaded into the top of the supply banjo bolt on the filter and isn't any longer than the bleed screw. Also I've had low pressure problems before I put my pressure guage on. Still completely confused. My overflow valve is a tork tek and is supposed to be factory adjusted. Not sure if I should mess with it or not.
Old Aug 16, 2015 | 08:33 PM
gorms's Avatar
Pressure should go well over 20 psi with a dead ended return line, up to 60 or more psi is indicating a strong lift pump. Lift pump sounds weak.
Old Aug 17, 2015 | 09:01 AM
patdaly's Avatar
20 PSI is nothing, it should spike to over 60 PSI with the hose pinched, if it didn't, either lift pump is weak, or something is preventing lift pump from sucking it from tank.
Old Aug 17, 2015 | 05:53 PM
Thanks for all the guidance boys. Looks like I'm going to have to order a lift pump.
Old Aug 18, 2015 | 03:45 AM
AlpineRAM's Avatar
Hey DirtyDozen!
Maybe you should look into https://www.dieseltruckresource.com/...ration-322212/ before going shopping.
One easy test is to open the fuel filter drain **** when the engine is running. It works best if you take a long transparent hose and route it to the fuel filler- that way you can see if you get air into the fuel.
This did a lot for Peter's 12V, power and boost are up, EGT is down a bit.
Just my 2c
Markus
Old Aug 18, 2015 | 05:16 PM
Thanks for the help I'll check for air leaks before I get a pump.
Old Aug 19, 2015 | 06:39 PM
MikeR's Avatar
Both my 12 valves, the stock lift pumps only got 150k miles, and had to replace them. I've done plenty other trucks around that mark, so no surprise it needs one.
As for the wastegate; if it's cracked just unscrew the boost line fitting and screw in a pipe plug, don't need a functioning wastegate anyway. As long as the spring in the actuator is holding the wastegate flapper closed.
CRToney
0
Nov 26, 2014 07:55 PM
Southtowns27
Jul 2, 2011 08:50 PM
jmlcolorado
May 19, 2010 10:30 PM
daveg
13
Feb 1, 2008 11:05 PM
