-   12 Valve Engine and Drivetrain (https://www.dieseltruckresource.com/forums/12-valve-engine-drivetrain-100/)
-   -   Low boost question (https://www.dieseltruckresource.com/forums/12-valve-engine-drivetrain-100/low-boost-question-197783/)
xzaq103 Mar 21, 2008 04:45 PM
Low boost question
Ok so I added my own custom plate last night kind of a stretched #10 ill get a pic later. Anyway its kinda laggy not much but still not like the 97 at the very bottom 1-4 PSI. What can I do to get rid of this AFC spring kit? Im going to try and adjust the star wheel a little tonight. Oh and the smoke screw is un touched. There is also no boost elbow because the part where the fitting screws into the afc housing if I try to take it off it will start to unscrew….. Ill try and get a pic of this for you guys Will the boost elbow help spool up down low?
Buckshotram Mar 22, 2008 12:29 PM
When i put the boost elbow on it made the turbo spool faster and "hit" harder. My AFC is foward and turned the starwheel a few times.
xzaq103 Mar 22, 2008 11:39 PM
Thats how my 97 was but i added the plate and elbow at the same time. any one know where to get an elbow?
