Lost power steering pump
Old Jan 7, 2015 | 12:06 PM
dougcarlo's Avatar
Started my truck at 0 below and ideled it into my garage, hour later tried to move truck now no steering or brakes. Got a steering fluid on my floor. I know I should have warmed it up. You think my power steering pump is out?
Old Jan 7, 2015 | 04:00 PM
patdaly's Avatar
Probably not, time to change the fluid.
Mine moans and groans as well, I'm right behind you in the need to get good fluid in.
Old Jan 7, 2015 | 04:33 PM
dougcarlo's Avatar
Well after searching old posts, found it happens when cold. Warmed it up for three hours and revved it up and started working. Not sure where it puked out oil. Thanks. I am going to search on how to change over fluid
Old Jan 7, 2015 | 05:38 PM
patdaly's Avatar
Typically the fluid will get contaminated over time and then when very cold,will foam out the cap along with moaning and not generally moving anything.
Easiest is to get a cheap turkey baster, and use it to suck out as much fluid as you can, refill, run it, then repeat for 4 or 5 times. eventually you get out most of the bad stuff.
I have been looking for synthetic PS fluid but can't find it around here, they say it works better.
Old Jan 8, 2015 | 09:09 PM
pind's Avatar
Amsoil synthetic atf. Best stuff I've found for power steering fluid. Only stuff I use in anything that requires either ps fluid or atf for the steering system.
I don't know much, but what I know, I stand behind
Old Jan 9, 2015 | 08:15 AM
patdaly's Avatar
Thanks Pind, coming from where you do, that recommendation is huge.
The funny thing is I always used ATF for PS fluid growing up and never had an issue...... I switched to PS because the experts said to....
Guess I had better order a couple of quarts and get out the turkey baster.
Once again, thanks!
Old Jan 9, 2015 | 09:48 AM
Rons red Ram's Avatar
Royal Purple at NAPA.
Old Jan 9, 2015 | 09:51 AM
Just pull the return hose off at the connection from the hydro boost (metal tube near fuse panel). Slip a hose on the end of the tube and stick in a container. With the engine running, fill the steering reservoir and it'll pump into your container.
Old Jan 9, 2015 | 11:49 AM
dougcarlo's Avatar
Thanks guys
Old Jan 9, 2015 | 04:12 PM
patdaly's Avatar
I have been told that, but ours just looks at you like you are from another world when you ask for it......
Old Jan 9, 2015 | 05:38 PM
I suggested it only because my NAPA has a Royal Purple display right at the door when you walk in.
Old Jan 11, 2015 | 11:22 PM
halfpint23's Avatar
Ah, better quicker easier way!
Any idea how much fluid I should have standing by to do this? I'm thinking I have KDP job coming up on the 97 (after I get 96 trans issues resolved) and can do PS fluid in 97 at same time.
Old Jan 12, 2015 | 10:55 AM
Robert Rausch's Avatar
I've been doing the turkey-baster method for years. I'll try this one next time. Thanks for the tip.
Old Jan 12, 2015 | 08:17 PM
Depends on how nasty it is. A quart or two of Wally World oil should work just fine.
Dean Snow
May 7, 2014 12:11 AM
Trace
Apr 2, 2009 06:42 PM
happeetxn
Jun 1, 2007 01:10 PM
mike7018
Mar 19, 2007 12:47 PM
j
Feb 22, 2004 10:59 PM
