losing power on uphill
No Power
Installed a #10 fuel plate and waste gate restricter, Blew the fuel line back to the tank to see if I had a restriction none that I can tell but still no change in power also cheaked the shut off valve and it is pulling it all the way up I am really stumped on this one any more idea's?
Either have the fuel pressure checked again or replace the overflow valve.
Good price> http://www.fostertruck.com/Overflow_valve.htm
Easy 5 minute, one wrench job.
If the shutdown solenoid's boot is torn or missing the bottom of the solenoid bore might be full of gunk and it only feels like it's pulling up all the way.
Remove the solenoid and clean out the innards
Thanks Tate you the man took the shut off right off and it fell apart in my hands Took a large C clamp and snaped it back together and snap roasted the tires good job now if i can figure out why it go's in and out of lockup at about 50 to 58 mph i will be grinin.
Clean it up and replace the boot as long as you didn't lose parts.
The first time I learned about the shutoff solenoid was when my truck would not shut off. I had to leave the truck running while I went in the house and searched the forum to find out what it could be. Sure enough, the boot was shredded and luckily all the parts were just hanging there and I didn't lose anything. I think Genos has a replacement boot but I just used some bicycle inner tube and wire to hold it all together. Its been working great ever since.
Tip to make the solenoid easier to deal with when removing is to turn the key on and lift it up before removing.
That way the electromagnet holds it together until you get the solenoid up where it's easier to handle.
That is and easy fix you have with the lock up on the Torque converter. I had the same problem with my 95 and It was the TPS (throttle position sensor) . I replace it and was back running great. Later Don T
David Bever
05-08-2010 11:10 PM
