-   12 Valve Engine and Drivetrain (https://www.dieseltruckresource.com/forums/12-valve-engine-drivetrain-100/)
-   -   Loosening Fan Clutch Nut (https://www.dieseltruckresource.com/forums/12-valve-engine-drivetrain-100/loosening-fan-clutch-nut-329742/)
Robert Rausch 02-02-2018 07:34 PM
Any tips on loosening a stuck fan clutch nut? I know it's a left hand thread, and to loosen it I should turn it clockwise. I can't seem to budge it. I've tried to stick a screwdriver between the pulley bolt heads, but I can't budge the thing. I'm using a 36 mm fan clutch wrench I borrowed from NAPA.
gorms 02-02-2018 11:08 PM
I've had good luck with locking chain pliers (vice grip type) right on the fan pulley, with a good rag under it to protect pulley. Smacking the edge of the nut with a long chisel to loosen it (cw) can help free it up. Cheater bars/pipes can be your friend too.
torquefan 02-02-2018 11:26 PM
If you have access to an air chisel, place the tip on the edge of the nut, pointed in the correct direction, and a very short burst usually cracks it loose without any damage.
Robert Rausch 02-03-2018 01:26 AM
Great suggestions both. Thanks gents.
NJTman 02-03-2018 09:08 AM
Buy, or make yourself, a clutch fan wrench set.
Once the one wrench is on the clutch fan nut, I smack it with a hammer, which releases it.
I made my own set from scrap steel, but I've seen them for sale on eBay or Amazon for about $25
Robert Rausch 02-03-2018 11:12 AM
I borrowed one from NAPA and climbed up on top the engine and put my whole weight on it while holding the pulley with a screwdriver and I still couldn't budge it.
NJTman 02-03-2018 06:46 PM
Quote:
With a screwdriver, I couldn't get it to work either. When I did my KDP , I was replacing my fan clutch, and I used an impact gun. It damaged the clutch fan nut, but I didn't care.
If the nut is that tight, you will need the big mouth wrench for the pulley bolts, and the smaller wrench for the nut. Smack it with a hammer, and it should come off. Try heat before might help. The threads will most likely be clean, once removed, unless something screwy went down
See here. https://www.dieseltruckresource.com/...y-92-a-305946/
patdaly 02-05-2018 07:06 PM
A solid whack with a brass drift will usually make it a simple task to take off. The sharp vibrations usually break the bond.
Robert Rausch 02-05-2018 07:18 PM
Thanks Pat. I'll try that.
NJTman 02-06-2018 08:53 AM
Yeah, thanks Pat!
BigIron70 02-06-2018 07:15 PM
1 Attachment(s)
I use this tool works great removing and installing
BigIron70 02-06-2018 07:24 PM
Takes any fan off in 2 seconds.
deere country 02-06-2018 10:17 PM
I posted a picture of that pneumatic set a while back. It works better than any thing else I have used and best of all you don't run the risk of destroying the nut with an air chisel.
I have had some that still took some taps with a ballpean hammer before the air tool set would take them off.
torquefan 02-07-2018 10:50 PM
Quote:
Very true, have used that before as well. Someone sure came up with a brilliant invention.
Robert Rausch 02-07-2018 11:17 PM
Those pneumatic sets are expensive little buggers. I think I'll make my own. Thanks for the great idea. I'll let you all know how it goes.
Copyright 2017, DieselTruckResource.com
