Let's talk about engine coolant...
Old May 8, 2007 | 08:42 PM
wcbcruzer's Avatar
What brand/type of engine coolant do you guys use? What do you recommend? Will Supertech "universal" greenish/orange coolant work well in these engines?
Old May 9, 2007 | 09:55 AM
infidel's Avatar
Since there were only two plants in the US producing antifreeze until one burned down I highly doubt there is any differences between brands except the label on the jug.
Old May 9, 2007 | 10:19 PM
CR785's Avatar
I agree, but i would use the same color antifreeze unless you change out everything and flush out the system.
Old May 9, 2007 | 11:43 PM
wcbcruzer's Avatar
Thanks Infidel.
Yeah, that's what I always thought. See the Supertech says it is compatible with ALL other types of antifreeze, regardless of color. But I'm not sure if it's still a good idea to stick to the same color or not. Also, since this is a diesel engine, if there was a "more suitable" coolant. Kinda like how we use Rotella/Delo 15w-40 instead of any 10w-30 engine oil.
Old May 10, 2007 | 12:03 AM
Mt Ram's Avatar
You should only use a high quality HEAVY DUTY anti freeze for diesel engines. If it doesn't say for diesel engines on the label, DO NOT use it in a diesel engine. Diesel engine anti freeze or coolant has special additives ( sometimes called DCA) that prevent erosion of the outside of the cylinder walls. It is also important to change your coolant periodically because these additives wear out. I just changed my coolant and I used John Deere pre mix anti freeze/coolant. It is pre mixed with ph balanced water. John Deere recommends that this coolant can be used for 5 years or 5000 hours.
Hoss
Dec 10, 2005 02:30 AM
DRM
29
Jan 12, 2004 11:13 AM
doomgaze
Mar 5, 2003 10:40 AM
Stamey
22
Jan 2, 2003 09:27 AM
