KDP repair parts??
KDP repair parts??
Can anyone tell me of a good supplier of the parts needed to do a KDP tabbing. I need a cover gasket,seal,tab, what else? Cummins stuff prefered or other top quality.
Thanks.
Thanks.
I used the tst kit, came with directions, all went great. I also purchased a new gasket from the local Cummins dist. (1/2 the cost of the dealer) preffered to only do this once with no leaks.
Originally posted by XLR8ER
the tst kit doesnt have a cover gasket? does a guy need it?or is that the permetex
Goop only will work.
how bout my 97 though? is "goop" ok there
The old one that came out looked exactly like the new one just with a little Rotella on it.
I would have taken the old one and cleaned it up with degreaser and smeared the sooper-dooper grey silicone supplied in the TST kit.
Oh, do yourself a favor, if you go back with the gasket(new or old) and grey silicone, get two longer metric bolts and cut off the heads and thread these into the accessory case bolt holes top and bottom to initially help align the gasket and cover plate while covered in silicone. I did it without it and did just fine... The thought occurred to me as I was getting it lined up and starting the capscrews.
Others have recommended this little trick too.
Keith
sootnsmoke
01-05-2012 08:55 PM
CTD_Neil
07-19-2005 08:13 PM
