KDP Carnage: Turns out this actually happens.
I hope the JB Weld works for you. However, what worries me is that the rock solid case is important as it maintains the close tolerance between cam and pump gear. If there is greater flex or torsional movement to a broken case I would hate to see further damage arise. I am sure every fracture is unique so it is hard to know which broken case will hold up and which ones won't
I hadnt thought about that before but in this case i don't see it being an issue. The gears are fastened to the "backing" part of the housing, and the break is mostly on the part that is basically a shell or ring on the outside. Kind of hard to understand I know but it looks to me like they should still have a good amount of support. Not sure how much rigidity the cover adds but that won't hurt either.
I just replaced the crank seal and put the cover back on, now it's time to reassemble and see how she runs. I'll probably wait till tomorrow to fire it up just to give the epoxy lots of time to cure. And because I'm scared...
Between the case and all the bolts on that timing cover, it is pretty doggone solid.
Well I done fired her up and she's running fine, no leaks that I can see. Gonna take it out on the highway and see if everything sounds and feels right.
The future looks bright!
Better way> http://www.cumminsforum.com/forum/94...ml#post2349170
I think you'll be fine. My break was over 4 inches of the outer lip the just disintergrated. It never had a problem and the guy that bought the truck 6years ago never called to say it was a problem as he promised to do. It's strong stuff.
I've put a few miles on and everything seems ok. I am jumping at the slightest sounds though. Now I'm waiting on a new set of tires and I think I'll have to buy a new washer fluid pump for $90 as I seem to have lost mine.
I am not sure if you could put a borescope ( miniature camera ) in and see it that way.
Been there, done that.
