THE KDP and associates
I pulled the shroud and fan pulley after spraying everything with brakeclean and the oil leak is still a mystery. I didn't want to pull the timing cover till I know where to get a kdp fix and how much it will cost me to do so. I tried to pickup a timing cover seal today but that endeavor didn't prevail. I found that autozone can order one for a relentless $52 and change. Does the fix-it kit come with this seal? Mine hasn't been fixed by the way seeing as there was some paint on areas of that gray silicone. Any and all info is appreciated.[roll]:confused:
My kit came with the seal. tst products(KDP-03) $48
The TST kit comes with Permatex, tab, longer bolt, crankshaft seal, and EXCELLENT instructions.
The TST kit comes with silicon sealant which will make a new cover gasket and a new crankshaft seal along with the tab and longer bolt for the KDP.A good value at about $50.
Sure sounds like it. where can I find one of those? I need one. Is that all you need? It sounds almost too good to be true.
on the cummins at work it was leaking oil, tightened up the timing cover bolts and that solved that. maybe with some luck thats all you need to do as well!
Originally Posted by Ru rammin 2?
(Post 1891317)
http://www.tstproducts.com/index.asp...PROD&ProdID=64 |
