jet power chip
no theres LOTS you can do performance wise but has nothing to do with the computer.
3k GSK springs, fuel plate etc. etc.
Just do a little reading in the 12V forum and you'll have lots of info.
thanks dr evil , but i have another question for you i have alow rpm noise that i can't get rid of it does it the worse at about 1800 rpm and sounds like it is coming from the drivers side of engine. it sounds like an air leak. i almost changed intercooler boots but decided to check with soapy water first and found no leaks. when get rpms up enough were you can hear it really good and press the clutch the sound stops but when let back out on clutch the noise resumes?
bansh-eman
Jan 27, 2008 02:48 AM
Elk_Hunter
Oct 24, 2006 03:17 PM
