in a jam
Old Sep 5, 2007 | 05:34 PM
DIESELBLOOD's Avatar
in a jam
when installing a #10 plate what happens if you slide it all the way to the rear of the engine my #10 didt come with a guide plate ??????
Old Sep 5, 2007 | 05:41 PM
satburn's Avatar
That's the least amount of fueling you'll have with the plate. Towards the tranny is weakest, towards the radiator is more.
Old Sep 5, 2007 | 05:42 PM
thanks for the reply so all the to rad is best or in between
Old Sep 5, 2007 | 06:46 PM
satburn's Avatar
Since you got gauges play with it. To the rad is going to probably roll some pretty good coal when you lay into it. All depends on what you want. Just watch your gauges. If you got an auto and it hasn't been prepped, I'd go easy with it. A #10 isn't as bad as a #100, but still you're turning stuff up and your tranny won't like it.
Old Sep 6, 2007 | 10:52 AM
jlipskoc's Avatar
Remember to adjust the governor arm correctly any time you move the plate beyond the factory specs.
http://www.piersdiesel.com/TechLeverAdj.htm
mikmaze
Jan 5, 2006 01:18 PM
JohnnyH
Feb 16, 2005 09:57 PM
hotdram
Dec 8, 2004 11:27 AM
Chad Layton
14
Aug 28, 2004 01:10 PM
Evildiesel
Oct 29, 2002 05:22 PM
