invisible railroad-ties - Page 2 - Dodge Diesel - Diesel Truck Resource Forums
Old 10-29-2017, 03:17 PM
Yes, now that I've been attempting to build an order for all moving front-suspension parts, I agree it's probably worth verifying in advance, to the extent possible, what's in need of replacement.
I need to dig into the FSM (or ask here?) about checking the upper/lower ball-joints for wear. Can play be felt just by jacking up and attempting to wiggle each wheel along the camber axis, or will the coil-spring-force tend to mask any joint-looseness there? Do you have to really haul on it to know for sure, maybe use leverage? When I did this a few weeks ago, I got only a barely-perceptible 'click' that I'm virtually sure was the same bearing-wear I've felt in that wheel before.
Had my third death-wobble experience the other day. I always expect other drivers to see that something's clearly wrong - maybe they'd think I've got a flat tire - but so far, no one seems to even glance over as I work my way to the shoulder, barely able to hold on to the steering-wheel.
'pants is offline
Old 12-12-2017, 09:20 PM
OVERTORQUED's Avatar
This reminded me of when I saw (you couldn’t help but notice) a gentleman in a Jeep, haulin down the freeway, when suddenly he experienced death-wobble. Threw that thing all over the road. When he got to the side, he jumped out of that thing looking like he shat his pants. Poor guy..
OVERTORQUED is offline
Old 12-13-2017, 01:13 PM
As some others commented, when I replaced a tire that was quite low on tread, the wobble-events ceased (apparently - it's been a couple of months now with no episodes). But I definitely need to replace bushings with the poly ones now sitting around, nagging me to get to them...
'pants is offline
Old 12-17-2017, 12:05 AM
i filled my ps pump with 140w gear oil. slowed that driping down a tad
joem is offline
Old 01-24-2018, 03:59 PM
FlaCracker's Avatar
I replaced everything on my front-suspension, reduced the frequency, but still occurred. Finally, put dual stabilizer shocks on front, solved the problem. Have not had problem since, been over 6 months.
FlaCracker is offline
Xonid
0
10-08-2007 09:31 PM
rockittboy
02-25-2007 09:37 PM
TRX24V
09-24-2006 06:20 PM
04ctd
03-29-2005 07:38 AM
firepiper
03-21-2005 08:26 PM
Quick Reply: invisible railroad-ties
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
