Intermittent low power - Causes??
Hi All, New to this site and so far I like it a lot. Hopeful I can get some ideas on a problem I have (had?).
I bought a '97 3500 5-speed about six months ago. It only had 115K on is and was in very nice shape. About three months ago (119K) I was traveling on a secondary road towing my trailer when I noticed a loss of power. I needed to keep downshifting to maintain speed and finally it died. Pushing the primer button on the lift pump then trying to start it showed it wanted to fire, but never really ran. Had it towed back to my place (yeah AAA!) and replaced the fuel filter and pre filter screen. It ran fine until a few weeks ago(122K). I was traveling a few hundred miles from home and went to shift. When I put the clutch in, the engine died. When I completed the shift and let the clutch up the engine started and ran fine. About fifty miles later while going up a hill, I had a severe loss of power and pulled over. Again the engine died when I put the clutch in. Got out and looked at the engine( why I don't know) everything seemed fine. Got back in and started it and it ran fine again. By then I was close to home so I just kept going. A few more times I lost power, but the engine kept running, then picked back up again. This time I installed a new transfer pump, bypass valve and replaced the rubber portion of the fuel lines to the engine. Took it for a fourty mile test ride and it ran like a Swiss watch.
I plan on going thousands of miles away next month and don't want to have a repeat while I'm at the mercy of some st ealer. Have these symptoms occured to anyone else? Is there ANYTHING I have left out that could possibly cause these symptoms to reoccur? My confidence in the truck is shaken and I won't put enough miles on it before I leave to feel comfortable.
Sorry if this is long, but I want to be as accurate as possible regarding the symptoms.
have you change the fuel filter again and cleaned the fuel screen,if so was there anything visible that is plugging filters,you might have a bunch of junk in the tank,what about the air filter.
Take a 4" piece of clear line and insert it at the IP fuel inlet, the banjo bolt. Look for air bubbles. Get a fuel pressure gauge and hook it up, look for fuel pressure drop, especially under load. The line may run free of air under no load, but under load, things change. I have been going through hell with this. I am curious to what your problem turns out to be.
What J-fox Is Speaking Of Is The Fuel Shut-off Silinoid. This Could Very Well Be The Answer. Sometimes These Will Slowly Fail Or The Relay Is Not Making Good Contact. Does This Start When You Hit A Goog Size Bump ?
Thanks for the ideas so far.
Originally Posted by russ300h
This time I installed a new transfer pump, bypass valve and replaced the rubber portion of the fuel lines to the engine. Took it for a fourty mile test ride and it ran like a Swiss watch..
Thanks guys for the help. Another 300 miles and it seems fine.
This is getting to be an adventure. I haven't worked on diesels since before I could vote. Sounds like a new clutch in the spring as the throwout bearing is making a noise now! I will get to bomb it someday as soon as I get the mechanicals straightened out and the good weather returns.
Jim Lane
Jul 22, 2016 07:04 AM
mic646
Jan 26, 2009 06:06 PM
