Installing Ball Joints (having problem with axle hitting ball joint bolt)
Old Dec 19, 2009 | 10:43 AM
Wulzcat's Avatar
I have installed new ball joints in my 97 2500 4WD. These are Moog ball joints. After putting everything back together, I have found that the axle where the universal joint is, hits the top of the bolt and nut where the lower ball joint is mounted. Am I doing something wrong? I have checked the parts to make sure I have the right ones and have veryfied that i have. Please help, because I am stranded. Thanks
Stacey
954-551-1786
Old Dec 19, 2009 | 05:15 PM
smokeum99ta's Avatar
Are you talking about the grease fitting on the upper ball joint? If so just go to a parts store and grease fitting thats made as a 90 not one that has adapters to make a 90. And that should clear your universals.
firebill1720
20
Mar 5, 2010 09:23 AM
wcbcruzer
22
Apr 30, 2008 06:58 PM
FDC
Jul 16, 2007 12:51 PM
getblown5.9
May 2, 2006 10:01 PM
