injectors
Old Dec 16, 2004 | 05:22 PM
MY WORLD's Avatar
injectors
What is a good method for a first time injector change? A illustration would help guide me I'm going from stock to DD3's
Old Dec 16, 2004 | 05:45 PM
masonic-dodge's Avatar
Wayne
DD3s, what made you go with them? DDs come with instructions with pictures. I know you will love that. Mine came today!
CRIS
Old Dec 16, 2004 | 05:54 PM
MY WORLD's Avatar
injectors
cris,
PM is on the way!!
I decided after talking to DD-Steve. We reasoned the daily driving that I do would better suit the 3's.
Congrats on the new arrivals!!! How long can you look at them without putting them in? Does the instructions say what tools if any are needed? I've heard just a big blade screw driver or small pry bar. Did you think the lug nut idea thru?
Keep the shinny side up!
Happy Holidays!!!!
Wayne
Old Dec 16, 2004 | 06:02 PM
Wayne
I think the PVC pipe and a lug nut is the way to go, that way your not prying on anything. I'll do the injectors this weekend if its not going to **** anyone off.
The instructions tell you every tool you will need for each step(no brainer)
I'll let you know what size PVC and how long to cut it.
CRIS
Old Dec 16, 2004 | 06:24 PM
infidel's Avatar
3/4" pvc 1-3/8" long.
You want the pipe to slip over the injector and cover about half the threads when the other end is touching the head.
Old Dec 16, 2004 | 06:28 PM
Bill
You are the man, I knew you would give us the right answer and save me all that work.
Do you use a large washer between the nut and the PVC?
CRIS
Old Dec 16, 2004 | 09:30 PM
Rattlerattle's Avatar
pvc pipe?
I was a little more redneck and used a 1" bolt and a couple of washers. Worked for me.
Old Dec 17, 2004 | 10:22 AM
infidel's Avatar
Originally posted by masonic-dodge
Bill
CRIS
You can use a washer if you cut the pvc too short otherwise it's not needed. If you have a camera could you take a couple pictures removing an injector and post them here? Worth a thousand words.
Don't quite understand how a 1" bolt would help you.
Old Dec 17, 2004 | 11:09 AM
MY WORLD's Avatar
injectors
Cris,
The slow process of picture takig is the idea worth doing. Its lets the next guy doing this for the first time have a better idea on what to expect.
Rattlerattle,
Did the 1" bolt just screw into the top of the injector ? Did you pry it out after that?
Thanks guys,
Wayne
Old Dec 17, 2004 | 04:18 PM
OK guys
I'll take pictures this weekend when I install my DD4s. I went to auto zone and got an injector puller, only .63 cents after tax. After I take the pictures someone will have walk me through how to put them on the site. I'm not good with a computer
CRIS
Old Dec 17, 2004 | 06:57 PM
Sorry all,
Injector fuel lines off, bolt over injector, a couple of large fender washers and then a lug nut to pull the injector.
Same idea as the pvc pipe but I didn't have any pipe around.
Old Dec 17, 2004 | 08:20 PM
sewman's Avatar
I grabbed em w/vicegrips & pulled em out!
Old Dec 18, 2004 | 09:08 AM
berner's Avatar
I made a little slide hammer puller out of a metric nut, a 5/8" x 4 bolt threaded into the nut and a big socket. Worked great but I like Bill's method with the pipe better.
Old Dec 18, 2004 | 10:35 AM
Jim Fulmer's Avatar
I tried the PVC once but didn't have good luck (crushed), I did use a piece of 3/4 conduit about 1 1/2" long and an M14x1.5 pitch nut and it is too easy to get them out.
Jim
Old Dec 18, 2004 | 03:05 PM
MY WORLD's Avatar
injectors
Jim
Jim,
We have another option with the conduit.
Thanks
How did you get 793 hp with only a plate?
