-   12 Valve Engine and Drivetrain (https://www.dieseltruckresource.com/forums/12-valve-engine-drivetrain-100/)
-   -   Im in trouble, I stripped the band adjusting screw 47rh (https://www.dieseltruckresource.com/forums/12-valve-engine-drivetrain-100/im-trouble-i-stripped-band-adjusting-screw-47rh-308790/)
johnny7 12-18-2012 09:24 PM
So sorry to bother all, but I need some advise quick. I have a 1994 dodge 2500, 47rh tranny when I was adjusting my reverse band (inside the pan), I was using a 12 sided socket and stripped the hex head, I bought the right socket, and no go, it was too stripped. I might be able to hammer on a 6mm socket to undo the screw but can I remove the screw and replace it or will something worse happen if I take it all the way out. if not can I leave the socket on the screw head permenantly? any body know what to do? Am I screwed?http://www.dieselbombers.com/images/smilies/dash2.gif please, please
johnny7 12-19-2012 12:31 AM
i hammed a 6mm on, i thought it was close to the 72footpounds that it needed before backing off , I didnt want to strip it any worse so I just backed it off 2...socket is still on, its on there good...buttoned it back up and now NO second gear...before I adjusted it, it was really loose. the little arm was waggling and had a 1/3 inch of play, does that sound loose to anybody?
dodgetrucker75 12-19-2012 12:53 AM
72 foot lbs? 6mm socket???? I bet it was 72 inch lbs (6 ft lbs) for the correct torque, I'm not an auto trans guy but your specs can't be right on that small of a thread
johnny7 12-19-2012 01:52 AM
holy crap your right !!!, thanks so much for catching that...tomorrow morning I will pull the pan and fix that...do you think I killed the tranny?
thanks so much for posting, I have to pay closer attention to detail[duhhh]
cdennyb 12-19-2012 01:47 PM
1/3 of an inch...? try backing it off 1-7/8 to 2 turns from the 72 INCH POUNDS of tight.
j-fox 12-19-2012 04:27 PM
Set that play to 5/16 and all is good.
infidel 12-19-2012 06:17 PM
http://dodgeram.org/tech/transmissio...T_band_adj.htm
joem 12-19-2012 09:54 PM
above link is right, i just use a pair of vice grips on that inner square adjuster and hit it up hand tight. then back of the correct ammount of turns.
torquefan 12-19-2012 10:34 PM
Exactly. Done lots like that, and if you can't get the socket on there, that 5/16" will get it closer to perfect than it probably ever was from the factory.
johnny7 12-19-2012 11:54 PM
I want to thank everyone who responded, I posted this problem on several boards but you folks had the most helpful imput. I pulled the pan off today and redid the hole operation according to the genos garage paper. Yesterday I hammered a 6mm socket over the stripped adjustment screw and its holding..it also wont come off, so i hope it will be ok. I put everything back together and second gear is back!!! I did not give it a good test drive (just around the parking lot) but tomorrow Ill give it a decent drive. I could only get lucas atf I hope it works out. I also added a drain plug in the pan (should have done that a long time ago)...I cant believe nobody has ever done the "72 ft/lbs- 72 in/lbs before....I will post tomorrow with how it all turned out but I just want youall to know that this board rules for helping idiots like me get back on the road
infidel 12-20-2012 12:09 PM
I bet a lot of people have and something broke or stripped out.
Most probably wouldn't admit it.
j-fox 12-20-2012 03:28 PM
The rear band has nothing to do with 2nd gear.
The rear band is applied in reverse and manual 1st only.
Front band is 2nd gear only.
joem 12-20-2012 09:59 PM
what controls the 3rd and 4th? This is a RH trans btw
NE frmhnd 12-21-2012 07:44 PM
3/4, or D/OD, is controlled electronically by the computer. The gearing is all in the tailhousing.
johnny7 12-21-2012 09:35 PM
Hi all, everything turned out all right. I adjusted the bands and everything seems to be ok.
Scot pa - how did I loose 2nd when I cranked down the "in the pan" band, Is it possible when I loosend it up I loosend it way up ?
as of now 1st and 2nd shift clean, 3rd seems a little soft, and overdrive kicks in at different speeds 50-65 (I think its the TPS) the lockup was flaky until I added a lockup switch. after I adjust the TV cable its time to change the fuel plate etc.
