How hot is too hot??
Old Apr 7, 2007 | 02:40 AM
proudpapa97's Avatar
Hello,
I have a question as to the proper operating temperature. I have read the posts about the fluctuating temp guages etc, and I have that problem.
Out here in Arizona as everyone knows it gets hot. Today I was driving the truck and noticed while I was in VERY Slow traffic, my temp guage went above 190 a bit. This concerned me quite a bit as I have never noticed the guage go above 190 before. What is the danger zone temperature wise that I need to be aware of etc?
the outside temperature today was about 90-95 degrees
Thanks,
Steve
Old Apr 7, 2007 | 04:36 AM
lovinCTD59's Avatar
Honestly I wouldnt be worried about the temp untill your about 210-230 degrees. A little over 190 isnt a concern at all. Mine will spike up to just over 190 when im pullin a steep grade when its hot out.. Since you have fluctuationg temp gauge go ahead and get the 180 degree cummins T-Stat. that solves that problem and will help your out in that extreme heat too... Good luck!
Old Apr 7, 2007 | 08:17 AM
schoust's Avatar
Mine runs between 190 and 200 but I'm not running a reguler T-stat though. I don't think you have anything to worry about at all.
Old Apr 7, 2007 | 10:40 AM
cool, good to know.
Old Apr 9, 2007 | 05:34 PM
MY WORLD's Avatar
Are you saying the thermostat can be had with a steady temp. The Cummins guys said I could have one that has a large fluctuation.
My guage moves from 180 to 140. it also has trouble refilling the radiator.
I replaced the stat, pump & cap, due to an overheating issue.
The herad is studded & o-ringed.
Thanks,
Wayne
Old Apr 10, 2007 | 12:09 AM
1stGen545's Avatar
Use the OEM Cummins T-stat it flows a lot better than most aftermarket ones. Both of mine come up to temp and stay there all day long unless under heavy load.
Old Apr 10, 2007 | 02:16 AM
ScottN's Avatar
Wiping is normal and not an issue. It will stop before you ever get close to overheating.
Zeddy
May 27, 2007 07:42 PM
Sea:\>Drive
Jan 15, 2007 05:26 PM
PapaSmurf
Aug 14, 2005 07:13 PM
DODGE 92
May 29, 2005 10:14 PM
rmb93243
Aug 6, 2004 06:54 AM
