How does the timing slip?
Old Jan 10, 2006 | 09:00 AM
Iron City's Avatar
I've been reading up on bumping the timing and in some cases people say their timing had slipped. I was just curious, isn't the whole contraption gear driven off of the crank shaft? I would think this would be a pretty closed loop system. How does the timing "slip"?
Old Jan 10, 2006 | 09:03 AM
Mcmopar's Avatar
The Injection pump gear is not keyed, it is a "Tapered fit" and the torque of the nut holds it on. Sometimes they will slip.
Old Jan 10, 2006 | 11:27 PM
Dr. Evil's Avatar
Apparantely, they didnt tighten the nut enough from the factory...therefore, it tends toslip over time.
Old Jan 11, 2006 | 05:23 PM
Both trucks I've timed had the lockwasher smashed totally flat. Probably wasn't doing much to help keep things tight.
Old Jan 12, 2006 | 11:32 AM
turbo thom's Avatar
Whenever the nut is removed to set the timing, be sure to spray the shaft with a good brake cleaner, that leaves no film at all, before the nut is reinstalled and torqued. If you don't, you will be in there again doing it all over. The nut will not hold up to heavy rpm's.
..Preston..
Old Jan 12, 2006 | 03:41 PM
QD Contact Cleaner (for electrical contacts) is what Cummins says to use. It dries lighting fast - like 3 seconds if the engine is warm. Even in 30 degree weather the stuff is gone in 5 seconds.
txsmokindiesel
May 19, 2009 08:03 AM
gkrossander
Feb 4, 2009 09:08 PM
dkinzer
May 23, 2005 08:57 PM
Stamey
22
May 8, 2005 07:12 AM
BADodge2003
Aug 24, 2003 07:22 PM
