How do you make a valet switch?
Old May 9, 2007 | 11:31 AM
xzaq103's Avatar
How do you make a valet switch? Does anyone know a cheap and easy way to make one?
Chris
Old May 9, 2007 | 02:20 PM
crankbender's Avatar
All I did was run tubing (air brake hose) from the supply (off the manifold) into the cab where I put a needle valve. From there I ran the tube up to the Afc. Now I basicly have an in cab ajustable star wheel. I can cut air off fully and run in full valet, crack it open just right so I get no smoke, or open it up fully and lay out the black cloud.
Old May 9, 2007 | 02:55 PM
Lil Dog's Avatar
crankbender,
Thats a pretty good idea. A little more tubing, but still effective. Some guys just put a ball valve in the tube from the AFC to the intake manifold and lift the hood every time they want to flip it.
Old May 9, 2007 | 05:03 PM
I had wanted to put in a regulator to be able to limit the air pressure going to the AFC. This would effectivly give an in cab adjustable plate (throttle stop) while the needle valve would controll the rate (like the star wheel) the diaphram moved forwards.
There was one guy on here that put in the regulator. Can't remember who but I sure would like to hear how it worked.
Old May 9, 2007 | 11:54 PM
Lil Dog's Avatar
If you drill a bleed orifice in the needle valve (between the valve and the AFC diaphram) you effectively make a regulator. Just like the boost elbow for the wastegate.
Old May 10, 2007 | 03:10 PM
On mine I also put a bleed off valve on to try and "make" a regulator. It worked but was very hard to get set up and I could never get it exactly how I wanted it. I gave up on it and simply use the throttle valve now.
Old May 10, 2007 | 07:33 PM
jlipskoc's Avatar
Heres my valet, got it at Lowes, cheap, easy, great for when I put new tires on the truck, keep the shop boys from playing.
On the load dyno, same setup as signature.
295 HP - valet on
430 hp - valet off
Old May 12, 2007 | 11:47 AM
xzaq103's Avatar
For now my airflow is limited so im thinking this would keep my egts down.
Chris
signature600
Feb 22, 2004 09:30 PM
engcogod
14
Oct 21, 2003 02:17 PM
gunracer1
14
Jul 28, 2003 11:23 AM
Lance
Jun 11, 2003 10:06 PM
