hot rodding with used parts
HEY GUYS.<br>HAVE A 94 2500 4X4 AT,I WOULD LOVE TO HOT ROD<br>THIS ENGINE,HAVE ACCESS TO GREAT SELECTION OF USED<br>PARTS,WOULD LIKE TO PUT PUMP FROM 98 ON,WHICH<br>WOULD WORK BETTER,THE AT OR MT?<br>any info would be helpful
Re:hot rodding with used parts
I don't know the difference between the at and mt, but have a thought I will throw at you. If you know your 94 has been taken care of, I would suggest staying with your pump. You can upgrade it with delivery valves, yours have 131's and the later pumps have 181's. A 3,000 govoner spring kit and afc spring kit, advance the timing to 15. My 94 is putting over 400 hp to the ground with original pump.<br>Michael
1ST CUMNZ:<br><br>Welcome to the website!!<br><br>"Michael" has given you good advice on the pumps!<br>The pump you have with the automatic trans. is<br>"rated" at 160 H.P. If you were to buy a 98' (manual<br>tans. pump) it will be "rated" at 215 H.P. The big<br>difference between the pumps is primarily in the<br>pump cam. However, your 160 H.P. can be made<br>to really put out the power! Piers Harry @ "Piers<br>Diesel Research" (1-866-888-9396) is has a<br>"modification package" which will make your <br>truck FLY!! You can call him for details.<br>The "215" pumps can be expensive. I have<br>seen them in price ranging from $1500.00 up<br>to $2500.00. For alot less than that, your<br>"160" pump can be set-up to run very well.<br><br>--------<br>John_P
Strjock81
16
12-12-2007 09:53 AM
HOHN
07-11-2007 05:37 PM
duallydave
08-07-2005 09:38 PM
