holset ?s
holset ?s
On Holset turbos are housing sizes stamped inside the exhaust flange?? Is this the same for all Holsets? I have one that is stamped 17 inside the exhaust flange, intake side? Also, This housing is wastegated and has a vacuum actuator facing forward with a small AN fitting. How can I hook this up to make the wastegate work? My old stock 35 got the boost signal from the comressor housing on the turbo.. Last ? where can you find adapters to adapt the larger flange to the stock exhaust manifold? Does anyone have one they are not useing? TIA
