higher idle after driving a while
I've noticed this a couple times...drove home from work yesterday and by the time I got home the truck ('95) was idling at around 1100 RPM. Shut the truck off...counted to 10 and started it again...750 RPM.
Just curious what it might be? |
For grins, did you try kicking the pedal a couple of times before shutting it off at 1100 RPM Idle? My Brownie liked to get corroded on the throttle linkage bellcrank assy. You could usually kick the pedal a few times and she would settle down. I had to lube it every so often. Seemed like it didn't happen as often if I was driving her everyday.
1 Attachment(s)
Check that both throttle return springs are hooked up.
Some engines have one spring inside another. Others have two side by side. Attachment 57789 |
I tried doing lots of different things with the pedal and it just keeps going. It hasn't ever been above 1100...and it doesn't do it every time I drive it.
I will check the springs for sure. Thanks guys :) |
| All times are GMT -5. The time now is 02:31 AM. |
