high idle
Old Apr 30, 2009 | 10:52 PM
badley's Avatar
high idle
hey all got a quick question. I recently stumbled across a 96 12v 4x4 auto with 157k on it and the guy wants 4500 obo for it. Only problem is at a stop it will idle at 1100 to 1200 rpm, he says that he has never really tried to fix it and that he just needs some cash. So my question is what could it be worst case and how easy would it be to fix it.
thanks
Old May 1, 2009 | 12:16 AM
Buzz'nhalfdozen's Avatar
easy fix. the throttle linkage on the bottom of the pump just needs adjusted. takes a 10mm and an 8mm to do the job
Old May 1, 2009 | 07:46 AM
patdaly's Avatar
Could also be as simple as the linkage needing lubed.
My Auto truck will do this sometimes, especially after it has been setting for a month or two.
Old May 1, 2009 | 09:07 AM
crabbelle's Avatar
tell him 3800 as-is, take it home fix the trottle linkage, turn around and sell it for 6K
Old May 1, 2009 | 10:04 AM
infidel's Avatar
Throttle cable could be streched.
You might get it fixed for as there was a recall.
Go here to check, you will need the VIN Dodge Recalls
Don't go messing with the linkage length, it is set at a certain measurement.
If you change it you will lose full throttle range.
90 power ram
Mar 15, 2011 09:37 AM
kicker210
Dec 2, 2009 08:23 AM
cwrhnr
May 19, 2009 05:18 PM
jmccart
Jun 12, 2007 02:12 PM
dieselnewbie
Jan 18, 2005 10:48 PM
