Help truck wont turn over at all batteries are 100%
Old Dec 10, 2010 | 08:51 AM
bostongsx's Avatar
Cold morning here in boston so i let the grid heater warm up and tried to start the truck. It fired and died so I tried it again, same thing. Now I turn the key and have nothing. Please give me some ideas or things to check.
Thanks
Herb
Old Dec 10, 2010 | 09:49 AM
bostongsx's Avatar
After further investigation whatever happened took the whole electrical system out, no power to anything. When the key is in the ignition I have the loud signal coming from the dash, in the run/crank position I have a very faint buzz sound coming from a plastic rectangular box on the left side of the fuse panel.
Any ideas guys?
Old Dec 10, 2010 | 12:48 PM
haddixj's Avatar
sounds like a relay it should pull out more then likely you will have another one that is the same you can try swapping them and see if the truck will run
Old Dec 11, 2010 | 06:20 PM
kawi600's Avatar
It should fire up with the shutdown solenoid pulled up, but it sounds like youve got some larger issues there..
Old Dec 11, 2010 | 10:32 PM
jonny mopar's Avatar
whenever i have problems like this on ANY dodge truckor cars from the late 80 or 90's i start at the battery connections make sure there are not any broken or melted wires then i go to the fuse, relay box under the hood. check and make sure you don't have any corraded broeken,melted wires going in or outta there. try to jump the starter relay and see if it will crank.
It sounds like you have some bad wireing problems.
Old Dec 12, 2010 | 08:30 AM
blackimpala's Avatar
This has happened to me, just a loose battery connection.
Floyd
Old Dec 12, 2010 | 09:28 AM
caver77's Avatar
had and johhy +1
Old Dec 14, 2010 | 07:41 AM
bostongsx's Avatar
Floyd
That was the problem...thanks guys
mataman
15
Feb 9, 2012 02:39 PM
stealman1
Nov 9, 2007 11:07 AM
mulercr88
Jan 14, 2007 09:27 PM
qcstunter
Jan 9, 2007 04:10 PM
jiMMyCTD
May 31, 2006 08:00 AM
