| avengermike |
Jun 3, 2007 07:51 PM |
help with tc lock up switch
okay so i did the relay wire up so the tc would free if i hit the brake, but with the switch on or off or centered it locks my truck in 2nd or 3rd and wont use the tc. i had to pull the wire going to pin 11 and disconnect it and restart my truck to get all gears back and tc. i did notice in the write up relay pins 86 and 85 are in a dif place. starting with pin 87 and going right is as follows on the relay 87,87a,85,30,86. now the write up shows 87,87a,86,30,85. has anyone had this problem?[dummy]
