Has anyone heard of someone "Snapping" a cam in half on a 12v?
Old Jun 22, 2007 | 12:06 AM
Common's Avatar
Some guy told me he snapped his camshaft in half...
Stock truck..
Possible?
Old Jun 22, 2007 | 02:13 AM
PourinDiesel's Avatar
Anything is possible.
Old Jun 22, 2007 | 05:05 AM
97' CTD's Avatar
2nd Pourin
Old Jun 22, 2007 | 10:15 AM
turbo dreams's Avatar
i think it is relevant to how many rpm's you are turning on the stocker.
Old Jun 22, 2007 | 10:28 AM
gunracer1's Avatar
it has happened more than a few times. big pumps with a bunch of rack travel are real hard on the stock cams.
Old Jun 22, 2007 | 10:38 AM
Need95-00CTD's Avatar
All it takes is a poorly cast piece of steel, or a machining error buy the operator...So like said above, anything is possible, but not probable.
Old Jun 22, 2007 | 11:53 AM
Marty86's Avatar
I've seen it in a 350 Chevy. But it was from poor construction of the cam, and lack of lubercation that was the problem. That truck really was a friday truck, for sure, with all the other problems it had.
Old Jun 22, 2007 | 02:11 PM
thekidfan's Avatar
Not uncommon....unfortunantly! It seems to happen at the number 1 journal, so technically not in half.
Old Jun 22, 2007 | 04:17 PM
92DuallyCTD's Avatar
Right there above ^^ is the most simple direct answer when it comes to anything mechanical. Unless you do neutral-slam drag races like a or something!
Old Jun 22, 2007 | 11:20 PM
ratsun's Avatar
As said it has happened to a few of the higher hp p-pump engines, but I doubt it would happen to a stock one. F1 helix cams offer a bolt on gear to help prevent the failure.
Old Jun 23, 2007 | 12:32 AM
The bolt on gear is for gear walk which has nothing to do with snapping a cam.
Old Jun 23, 2007 | 08:31 AM
Dshiftff's Avatar
a little KDP action maybe.
Old Jun 23, 2007 | 08:44 AM
signature600's Avatar
Yeah but doesn't the bolt go clear into the 2nd bearing journal to help strengthen the nose of the cam??
Chris
Old Jun 23, 2007 | 11:33 AM
ratsun's Avatar
That's odd?
The way I understand it the walk is what allows the cam to break?
Perhaps you would care to elaborate?
Old Jun 23, 2007 | 11:38 AM
97' CTD's Avatar
My bolt on gear had a long bolt
Brandon
