Hard line from LP to filter.... (HELP!)
Hi guys, need help ASAP. I need the hard line from the lift pump to the filter housing. I am screwed if I don't get a new one before Monday as I start a job 100 miles from here and currently don't have another vehicle at my disposal.
Can someone hook me up with a part number or a place to get this line? I just discovered I needed a new one so I will be on the phone with dealerships tomorrow. I am panicking a little because this is a pretty obscure part.
Help is highly appreciated!!!
Thanks!!!!!!
Thanks!!!!!!
Relax, fuel tube from pump ( flare fitting ) to filter ( banjo fitting ) is Dodge part number 4761978 and the 2 sealing washers for the banjo end is 4638698.
That being said, for an emergency patch, just patch it with some rubber fuel line and hose clamps.
yeah- alwaysS check with Cummins first on engine parts. If it is on the engine it is 90% chance it's a Cummins part and will be cheaper from Cummins. Serp belts, for example, are Chrysler parts, but all fuel parts attached to the engine block, for example, are Cummins.
I've saved a bunch dealing direct with Cummins over Dodge and some of the diesel parts places. My oil pan was less new from Cummins then the junk yards online wanted for used ones!
Dargo
Jan 12, 2018 07:45 PM
icrider
Jan 3, 2010 04:51 PM
Joe V
Jan 18, 2004 06:08 AM
