Gray valve cover gaskets??
Old Jul 13, 2006 | 12:41 PM
JFellman's Avatar
When I replaced mine, the stock black ones had become very hard and were not sealing well. I have used the grey ones and even reused them after a valve adjustment...no leaks after 1 years use, then reused after valve adjustment....5000 more miles and no leaks. I didn't torque the bolts...just tightened down good after the shoulder bolts seated.
Old Jul 13, 2006 | 03:24 PM
turbo thom's Avatar
I bought 6 from Cummins and got gray. I bought a head gasket set from Cummins, and got 6 gray with it also. I would think gray is about all they have. but I will tell you this, if you ever take the cover off and it's still hot, you will say prayers 7 times a daytrying to get it back on. Every black one I've seen that came on the engine, was so brittle they would break when you removed um from the covers.
..Preston..
MARF75
Jan 15, 2011 10:31 PM
mt72916
Jan 18, 2005 09:43 PM
LanceD
Jul 6, 2004 01:32 PM
srowen
Jun 27, 2003 06:44 PM
mymaur
Dec 23, 2002 08:28 AM
