going to look at a truck, any heads up
im going to go look at a 97 2500 4x4, 5spd. with i think about 235k miles, are there any major things to worry about and if so what do i look for, also is the mileage something to be concerned about, im told this truck in in excellent shape and is a 1 owner truck, and advice would be great
seth
seth
I would get the front axle off the ground and check for slop in the front end, sure the motor will go for ever but ball joints won't. while it is up check the U joints as well, little things but they all add up and end up costing you more money, money you won't have for mods instead you'll be stuck fixing it back to stock condition. check for signs of frequent or the lack of maintenance, if all the fill plugs look real neat it hasn't been taken care of well.
Also ask to see
if the KDP has been done, if they say the what? or ask, chances are that it has not been taken care of. The mileage for that truck is nothing. These cummins engines can go 500K between overhauls if well taken care of. My truck has 170K and runs better than a new truck. DaveLx88 bought his with nearly 300K on it and its a solid running truck! I have a friend with 365K on his stock 12 valve and it still rattles right along. NO issues on it whatsoever... dont let the mileage discourage you on these trucks...
Tx
Tx
i just bought a '96 2500 4wd auto, with 255,000 miles on it. i had to fix the fuel gauge, kill the kdp, change all filters and lubes. went with synth in the trans., and it needed a track bar. all minimal ivestments in a good truck. i paid $4500 for it, great deal i thought.
Hammily
09-10-2007 10:43 AM
bsj04
06-30-2007 03:31 AM
Dieseldirt
10-05-2006 02:32 AM
Intercooler
06-06-2005 09:50 PM
