gauges and gsk kit installed how much boost
Hey guys I got my gauges installed today along with the gsk I got a #6 plate and a home made boost fooler I am getting 19 pounds of boost and I can run the egt's right to 1200* How much boost can I boost this engine and still be on the safe side? What a difference the springs make the truck feels a lot more responsive.
Re:gauges and gsk kit installed how much boost
I can get 28 psi boost at WOT with empty truck I have the #6 plate also
Wastegate disabled, no gsk, #6 plate I made 36psi. With the addition of 370 injectors only, it went up to 42psi, way off the efficiency map for the HX35.
Pappy what kind of egts are you getting empty Matt
Matt<br><br>At WOT and 28 psi boost the EGT will run around 1000-1100
Pappy are you running any special exhaust? I have killed the cat and put a 3" terminator muffler on. Matt
Not yet Matt I will be doing my exhaust soon....maybe just straight piping my stock setup
turned up the boost today and it brought my egt's down to about what yours is I am getting around 28-29 #'s of boost and a lot lower temps I love those governor springs what a difference Thanks for all your guys great information Matt
CGS:<br> Like Daniel said with the same set up I get 42-44 lbs of boost. I'm runnin a 14cm turbo housing and a 4" exhaust. EGT's seem to stay around 700-800 empty. Cruising at 1800 rpm in fifth over I stay at 600.<br><br> That help a little?<br><br>..Preston..
[quote author=CMNS_PWR link=board=16;threadid=9060;start=0#87053 date=1041459062]<br>Wastegate disabled, no gsk, #6 plate I made 36psi. With the addition of 370 injectors only, it went up to 42psi, way off the efficiency map for the HX35.<br>[/quote]<br> :o :o :o :o :o Dang Daniel!<br><br>With my factory plate & AFC housing full forward I can hit 30-32lbs of boost! Going up a hill I can hit 35lbs. but it comes right back down and I don't get a chance to see the EGT's!<br><br>Can't wait to get my GSK installed tomorrow!!
Got smoke you will love the springs I can't beleave the difference it made. I went through the side of the pump plumb easy to change the worst part was getting the rear bolt in the fuel shut off back in. Have fun Matt
