fuel shut off working????
Old Dec 6, 2004 | 12:00 PM
mx261's Avatar
hey guys, when you turn on the key, does the fuel shut off soleniod automatically come up? mine didnt so i pulled up on it and it stayed and started right up. any comments?
Old Dec 6, 2004 | 12:18 PM
infidel's Avatar
You have to turn it to crank the engine position for it to come up. The solenoid has two coils, the stronger lift up coil is energized by the starter motor. After it's started the hold up coil takes over. If yours isn't pulling up when you crank the engine the problem is likely the blue wire that comes off your driver's side battery is corroded or the relay on the firewall is shot.
Old Dec 6, 2004 | 12:24 PM
mx261's Avatar
ok i pulled it up before i cranked it. I just thought maybe that was the hard starting culpritt. I tryed adjusting my idle but the 10mm nut was way too tight and i dont want to round it off.
Old Dec 6, 2004 | 12:27 PM
Eskimo's Avatar
it moves up when you put the key to start, through the 70A relay on the firewall (a common failure point)
Old Dec 6, 2004 | 05:58 PM
mx261's Avatar
ok I think my plan of attack is this, Replace the lines tank to pump and check the pickup for leaks, fix as required. move fuel plate forward and adjust star wheel. also do the kdp thing while im at it. ? do i need a gasket or can i use rtv? And the last thing, No one has really piped up on the gas line versus deisel rated stuff. Any takers there?
Old Dec 6, 2004 | 06:05 PM
infidel's Avatar
Some gas line is compatable with diesel, others aren't and will melt.
Why take a chance?
Don't believe the guy behind the counter at the auto parts store.
Old Dec 6, 2004 | 09:40 PM
mx261's Avatar
I hear ya man but its either buy the gas line or stay at home
Old Dec 7, 2004 | 09:54 AM
infidel's Avatar
Try a boat shop, they usually have higher quality hose than you'll find at the auto parts.
Smokkin
Apr 4, 2012 02:43 PM
dkimmel
Jan 3, 2011 10:54 PM
randyswelding
Feb 9, 2009 10:40 PM
Dean Snow
Sep 26, 2007 03:40 PM
doomgaze
Dec 12, 2002 05:18 PM
